Bike with homebuilt engine
boutje
Post by boutje »
After helping with the build of the jawa dieselbike , i want built my own bike.
See the built i was helping with:
https://www.dieselbikeforum.com/view ... =31&t=1775
This are some specs of the new bike:
- homebuilt engine with parts of a yanmare clone (418 cc)
- a suzuki dr 350 6 speed gearbox is fitted (maybe a dry clutch??)
- homebuilt frame
- brembo wheels and brakes (17" wheels)
- cagiva mito frontfork
It will be a sporty looking bike.
I have already started with the design of the engine/gearbox.
Re: Bike with homebuilt engine
Sounds exciting. Can't wait to see pics and read the write ups as you go along.
Tetronator
Post by Tetronator »
I was waiting for this post ever since you told me about your plans, can't wait to see what you're going to tinker-up next! :D
Honda VT600 C Shadow
H̶o̶n̶d̶a̶ ̶C̶B̶R̶6̶0̶0̶F̶2̶
Mercedes-Benz W123 300D Sedan
boutje
Post by boutje »
I started with making the easy parts.
Here are the first parts.
A set of triple clamps.
Made out of 6082 T6 aluminium.
Cnc milled.
Front fork of the cagiva mito
Raw piece of the triple clamps.
The design of the triple clamps in the cad cam software
boutje
Post by boutje »
After some frame calculations i have more specs of the new bike.
Wheelbase : 1390 mm
Castor angle : 25 °
The front wheel will be a 17"x 3.00
The front tire 110/70-17
The back wheel will be a 17" x 4.00
The back tire 150/60-17
The next thing i going to do is design and build the swingarm.
Tetronator
Making good headway on the bike I see, keep it up! :D
Blunt Eversmoke
Post by Blunt Eversmoke »
Homebuilt engine? Now that's something I'd love to hear more about :) Displacement, cyl count, layout, injection, induction? 2 or 4 stroke?
Mouse
Post by Mouse »
Good to see someone else using CamBam.
boutje
Post by boutje »
Mouse wrote:Good to see someone else using CamBam.
I have several cadcam programs.
But i find cambam the best one.
boutje
Post by boutje »
Some update on the build.
I have bought a set of ligthweigth brembo wheels.
Set of wheels
Set of wheels
boutje
Post by boutje »
And i lost more weight on the wheels by removing the spoke covers.
Each cover weighs 500 gram.
So the total weight reduction is 1.5 Kg each wheel.
The next step is to sandblast the wheels.
Total overwiev of the wheel without covers
The spoke without the cover
Closeup over the wheelcover
Aerodynamic drag w/out those covers might be more of a gain then the weight you reduced? Besides what weight you keep you want down low. But judging by your post you know shiats more about this stuff than I do :oops:
boutje
Post by boutje »
You are absolutely right about the drag.
But the advantage of light wheels are much bigger than the drag isseu of the wheels.
Light wheels give a much better handeling in corners (specially good for the suspension) , better braking and a better acceleration.
Blunt Eversmoke
So, what about the homebuilt engine? Can't wait to hear the details :)
boutje
Post by boutje »
Still working on the design.
I'm very busy with my own business , so the project is not going fast.
But it will be a 416 cc one cilinder.
With a cassette gearbox , external fuelpump , overhead camshaft and liquid cooled cylinder.
boutje
Post by boutje »
New start with the project.
Because i was very busy in my own company (making motorcycle parts and building motorcycles) i had no time for this project.
I started with the engine build a few weeks ago.
First i wanted to build a complete new engine , but i took a suzuki dr650 engine as a base.
boutje
Post by boutje »
And back on the project.
and from now on I will continue with the diesel every Saturday or Sunday.
I took a piston from a lifan 192 diesel because the piston pin exactly matches that of a suzuki dr650.
boutje
Post by boutje »
the piston is about 6mm higher than the dr650 piston.
but a new cylinder liner has to be made.
make it 6 mm longer and make a pocket into the cylinderhead .
cheesy
Post by cheesy »
Cool.
Mike
2004 Lombardini 15LD315 looking for a steed
1979 Honda CX500
1977 VeloSolex 4600 V3
1973 VeloSolex 3800
2007 Ural Gear Up
"I don't even care about my problems, why should I care about yours?"-A quote on a favorite t-shirt
