Battery and alternator: common connections?
touchwoodsden
Post by touchwoodsden »
The alternator on the Smart Diesel engine is right by the starter motor.
Is there any reason why the main alternator power lead cannot be connected to the main starter terminal actually on the starter, because after all, they are connected at the battery anyway
I’m thinking of it reducing the number of connections to the battery.
Thoughts anyone?
Regards
Merc Estate
BRA CX 3
2 CV Dolly
2 x 250 MZs
1 x 125 4 stroke MZ
2 x 301 MZ
1 x Enfield Himalayan
1x Monkey bike
1 x Honda CT125
1 x Campervan Vivaro
1 x MZ Es250/1 and sidecar
1 x Cat
2 x Parrots
16VGTIDave
Post by 16VGTIDave »
No problem with that, as long as the solenoid (starter relay) is on the starter. If it has a remote solenoid (relay), then no.
Many cars are wired this way.
touchwoodsden
Re: Battery and alternator: common connections?
16VGTIDave wrote:No problem with that, as long as the solenoid (starter relay) is on the starter. If it has a remote solenoid (relay), then no.
Thanks Dave. It is indeed on the starter.
Merc Estate
BRA CX 3
2 CV Dolly
2 x 250 MZs
1 x 125 4 stroke MZ
2 x 301 MZ
1x Monkey bike
1 x Honda CT125
1 x Cat
2 x Parrots
UAofE
Post by UAofE »
No problem. The alternator isn't spinning fast enough at cranking speed to change the current flow. Once the starter is off, its just another wire terminal.
gearhead1951
Post by gearhead1951 »
In the battery box 1 connection to ground and the + to input on a connection box mounted on the outside of the box ! Battery and primary connections covered and all other connections made in junction on the outside !
touchwoodsden
gearhead1951 wrote:In the battery box 1 connection to ground and the + to input on a connection box mounted on the outside of the box ! Battery and primary connections covered and all other connections made in junction on the outside !
I thought of that. I am using a 200 amp isolator switch to do the same thing
Merc Estate
BRA CX 3
2 CV Dolly
2 x 250 MZs
1 x 125 4 stroke MZ
2 x 301 MZ
1x Monkey bike
1 x Honda CT125
1 x Cat
2 x Parrots
touchwoodsden
Merc Estate
BRA CX 3
2 CV Dolly
2 x 250 MZs
1 x 125 4 stroke MZ
2 x 301 MZ
1x Monkey bike
1 x Honda CT125
1 x Cat
2 x Parrots
