Complete Comet 500 CVT
dieselbikin
Post by dieselbikin »
Going on eBay today 7pm central. 6A320-58862 6A320-58862
Comet 500 series CVT in great condition and complete with belt for center to center of 9.5". This would be close to $500 new with belts. Driver has 1" bore, driven 3/4" bore. Those model set up for lower rpm Briggs type engines. I used it shortly on a 10HP diesel motorcycle. HP Range: 2 cycle; 25hp, 4 cycle; 16hp, Engagement: 2100 RPM Diameter: 5-3/8", 3-roller Cams, Calibration: Spring Ramp, Weight. Asking $300, 256-230-5006
[URL=http://s488.photobucket.com/user/d ... jpeg[/img][/url]
1980 Suzuki 550
10 HP Yanclone
94C Comet
bf109v7
Re: Complete Comet 500 CVT
Post by bf109v7 »
What is the recomended distance cankshaft to jackshaft with your belt?
Alex
You don't have a comet 500.
On yours the distance should be 8 3/16 inches or nearly 208mm.
https://www.gokartsupply.com/tcbelts.htm
bf109v7
Post by bf109v7 »
I know what I have. A bad chinese copy of the COMET 40. And I want to know wheter I could use yours, I would buy it in from you but you woud have to tell me the shaft distance so I can see whether it is in the range of what I can modify.
Alex
I have no connection to the link I posted it was just to show sizes.
I don't think you can fit a 500 belt to a 40 series as the sizes are different.
Your centres need to be 208mm apart to fit a standard belt. It's possible if your belt is too slack you are getting slip which will cause wear in the belt.
bf109v7
Post by bf109v7 »
I know all that. And I told you that I can modify the distance within limits. But I and anybody who want to buy your Comet 500 has to know for what shaft distance meant. If you dont want to give this information, nobody will buy converter. I can not find the belt number on you picture in the net, I found this only: https://www.gokartsupply.com/tcbelts.htm
Why do you want to keep this information secret?
Alex
I am not the person selling the Comet 500 !!!
I was just trying to help but I won't bother!!
bf109v7
Post by bf109v7 »
Sorry, I did not look for the name, because I did not expect somebody else than the seller to answer my question. Lets see,he should look into the forum and it should be easy for him to anwer my question.
Alex
dieselbikin
Hello, I'm the seller. I did a quick center to center and it was approximately 9.5".
1980 Suzuki 550
10 HP Yanclone
94C Comet
