Hi
Found surplus to requirements as I have moved on to manual diesels . There are photos on the EBay advert http://www.ebay.co.uk/itm/301758518534? ... 1555.l2649
Micro car variator
Complete variator CVT system including crank mounting taper which from experience is easily modified to fit the kubota engines both 2,and 3 cylinder range
The centre guide bushes and idler bearing, and pulley sheaths in good condition , weight guide block shows signs of wear but its still within service limits. When needed Replacements will Cost £7 each from Greys of Thrapstone
Belts is in as new condition.
Rear variator is in good condition but does have light surface rust on the shaft. This needs to be removed before use.
mounting size required is 19mm + a keyway (actual key is still in the unit)
ALSO Included is a home made jack shaft to fit the rear variator and mount on 25mm plummer or flanged type bearings Its has a key way cut in to it .
Comes with spare diesel rear and front variator Spring and additional front weighs if you are using it on a Diesel engine to suit its slower running .
Also included are two covers .
£120
Located a BA77PA Tel 01963 350668
Cheers Tim
Sold Complete CVT system for sale (uk) Sold
Re: Complete CVT system for sale (uk)
What's the diameter of each part? Belts, what sizes do they come in?
Right now im using a comet 40 with a 7 1/2 " driven, and its a snug Fit.
Hi there
Sorry for the slow responce !
The Driven pulley is 200mm Dia the Drive pulley is 192mm Dia and the belt circumference is approx 920mm ,.I also have a homemade jack shaft that fits the Driven pulley which takes standard flange or plummer type bearing blocks.
Cheers Tim
Cheers Tim
Re: Sold Complete CVT system for sale (uk) Sold
HI Tim
Any source on the rear spring, I have reached the limit of tweaking using the front weights as it now drags a bit at idle. Need to play with the rear spring pressures unfortunately.
