Electronic Diesel engine control blog
ECU's, Mapping, New Injection systems, etc
Thanks to Peter for sharing this with me. Not sure it's quite common rail but it's a step in that direction away from traditional Diesel engines.
http://blog.arduino.cc/2014/02/25/an-el ... #more-8970
Re: Electronic Diesel engine control blog
I have seen this before, it looks really good, easy to do if the engine was previously controlled by some sort of ecu, bit more difficult with fully mechanical system like the yanclone
Mouse
Post by Mouse »
I am putting my 1900 VW powered Dnepr back on the road using the TDI engine which has the VP37 fuel pump on it
I am currently helping Juho with the development of the pump head position feedback circuitry. Currently it can only use the much less common resistive head making his control system virtually useless for the engines available in the breakers. I hope to sort him out with being able to use the common inductive pickup shortly after the Big Knock.
It is a very interesting project which gives complete control of all the engine parameters.
Wow that would be great.
I wonder if there are any eletrically powered unit injectors or injection pumps that we could use on the yanclones. Imagine variable injection timing, it would make these engines so much better around town.
Any thoughts on any engines that have these that arent common rail, and can be restricted down to one injector?
