Those who run open clutches?
Clutches, Chain & Belt Drives
I rode my diesel bike for the first time I'm a couple of weeks, and after a couple of miles my clutch was very stiff and Either the clutch started slipping.
It has been raining over the last week and I have realised it's probably the lubricant has been washed away! I will be pulling it apart and greasing everything again.
Has anybody had any similair experience?
Re: Those who run open clutches?
Post by Anorak_ian »
Yes! :lol:
Bob Newby clutch by any chance? :x
Dump the crap open bearing clutches or you will have no end of adjustment and rebuilds.
It's a 1970's design, the real manufacturers changed the design years ago.
Look familiar?
http://www.ebay.co.uk/itm/350975973178? ... 1438.l2649
This is the 3 spring version.
Note the bearing ring, this is worth buying if you do have a Newby clutch. It will stop the bearings bunching up and causing friction, ie clutch drag. Mind you, you'll still have to lube it up, over and over again.
I run an open clutch, but mine has enclosed bearings. A damn good clutch!
It is a Villiers clutch. Can't remember the exact assembly it was from but I have since removed the open roller bearings and had the center turned out and used a sealed bearing in its place.
The problems I was having was from the first steel plate missing it's key hole. Which meant it didn't run concentrically.
All sorted now :)
Lol, I just noticed the date of your first entry. :D
I've had the BNR clutch off for re-greasing this week. Well, the toothed part is BNR but the back part is homemade and yes, I suspect those bearings bunch up. It's done 4 trips to Hamm & has to be greased up pretty regularly.
I need a sealed unit to slip in there!
Crazy, I just remembered I still have my Bob Newby clutch on a shelf in my garage. Been there for years :lol:
Well that's one for ebay. :D
Anorak_ian wrote:Lol, I just noticed the date of your first entry. :D
Heh
Stuart wrote:I've had the BNR clutch off for re-greasing this week. Well, the toothed part is BNR but the back part is homemade and yes, I suspect those bearings bunch up. It's done 4 trips to Hamm & has to be greased up pretty regularly.
Get a sealed bearing in there. I used a thin wall bearing and haven't had any problems
Heh
Well it's been a while. If I had noticed the date of your first entry I probably wouldn't have said anything, as you would have no doubt, fixed the problem by now.
alexanderfoti wrote:Get a sealed bearing in there. I used a thin wall bearing and haven't had any problems
Glad you used the term 'thin walled' as I'd never have found them :)
