Compounds to seal leaky fuel unions?
Post by mark_in_manchester »
Hi All -
My fuel system leaked all over my alternator, which eventually caught fire...the plumbing is made up of old laboratory compressed-air fittings, valves etc - which fit together using compression fittings / olives on small bits of stainless 1/4" pipe. It's a 2 tank system so there are 4 valves (2 send, 2 return) and lots of unions. Unfortunately it leaks...I was thinking of having a go with Blue Goo (hylomar) and / or plumbers PTFE tape...has anyone any experience of how this stuff reacts to diesel? Or suggestions for anything more suitable?
cheers
Mark
Re: Compounds to seal leaky fuel unions?
mark_in_manchester wrote:... or plumbers PTFE tape...has anyone any experience of how this stuff reacts to diesel? Or suggestions for anything more suitable?
Not sure about straight diesel but have heard PTFE Tape issues with biodiesel and veg. oil fuels.
I came across blue hylomar in my fuel line when I had the tank off the Ruggerfield. It had broken up some and gone quite hard. It was inside the nuts up at the tank end and I cleaned it off. There was some in the pipe even. Leaks followed until I tightened up the nuts more. Now I find nothing leaking down the pipes but a small puddle under the bike. Tightening an Injector stack solved the problem - for a while - but I digress. That's the only experience I have of hylomar and diesel. I think the PTFE tape should be a better option. Less likely to be affected by normal rather than Bio I'd imagine?
Shite...I've gone all over it with hylomar. Well, I guess I'll keep an eye on it and see how we go. Thanks for the responses - I'll update this next time it fails...
cheers
Mark
realnutter
Post by realnutter »
The stuff you need is called Calortite.... It's a red non-setting goo designed to seal gas pipes..... but it's completely ok with diesel.... dinousaur derived diesel that is...never tried it with veg....
readily available from chandlers.....
