I am a rider with 2005 kawasaki zx130 - small 4 stroke - 10 HP - 1 cylinder - air cooled - gasoline bike engine...fffuhhh.....
Interested in this forum to find out if it is possible to turn my bike engine into using diesel...can anyone help with possible step-by-step guidance i can use ? Thank you so very much...
As for an alternative, after viewing the GEET Fuel System, an idea come up to try at least to replicate some of this system. What about..mmm, if I have 2 fuel tank, one filled with gasoline / diesel fuel, and another with.....ordinary tap water.
See, the water from the tank then goes trough some small fuel pipping, with some kind of fuel regulator trough the inner pipe in the exhaust system, going in the opposite direction from the exhaust gas flow. This water then will be heated up with the exhaust flow, out near the beginning of the exhaust pipe in the form of Hidrogen and Oxygen gas ( after being heated ), then goes trough a small fuel pipping system again and mixed with the gasoline / diesel fuel in one pipe before going into the carb intake.
The carb then can suck this combine fuel because it is a vakuum carb.
Sounds weird or possible ? Any suggestion ?
The only reason i propose this is just because i want to improve my bike fuel efficiency, so for all the pros and contras i welcome thee...
So far, as to improve the fuel efficiency, I have been playing around with Side Gapping Sparklug trick and mixed gasoline with acetone ( 3ml acetone per 1 litre gasoline ).
The best session achieved so far : 1 litre of gasoline for 77 km ( I'm hoping to improve this if I can manage to convert this engine into diesel )
Thanks again,
( * so sorry if my English is not that good, cause i'm from the asia )
