cooling turbo with diesel inst. of water?
Doing stuff with air...
klondikekid
Post by klondikekid »
I seen some talk about using diesel fuel through the turbo water jacket for cooling instead of hooking up to cooling system, I have the hoses and fittings to go to the water jacket but just running my fuel line in and out of the turbo would be alot easier, and any benefits? yay or nay? Has anyone here got real world experince doing this, how did it work? problems?
Re: cooling turbo with diesel inst. of water?
Post by BertTrack »
Cooling jacket? That must be a huge turbo!?
Heating your fuel too much may cause an early burn. And would make the engine more vulnerable to knocking.
klondikekid
No, it's very small turbo, Garrett GT12 it's just a baby, good quality, compared to the junk on flea bay from china, that doesn't have a jacket. I can't remember where i seen the thread on here, but there was talk of doing this or having done this and the talk sounded like it's been done before, I'll see if I can find the thread. Valid points though BertTrack.
are you talking about cooling the actual turbo or cooling the air from turbo (intercooler).
UAofE
Post by UAofE »
Diesels do not need the turbo cooled. The lubricating oil cools it plenty.
klondikekid
Yes, I'm talking about the liquid cooling in the water jacket of the turbo. I have seen a lot of talk back and forth on the web about not hooking up the cooling lines if the turbo has them, makes sense to me if you have the cooling jacket to use it, hot shut off's, coking the oil, bearing life etc. might be ok without, but this turbo cost me aprox. $1000 brand new...hate to find out the hard way, especially if it was designed to be cooled. Done some looking around on the web, and it seems that room temp. is best for diesel fuel temp. going into the engine, makes sense, just thought I might be missing something after reading about someone running their fuel line thru the turbo instead of water/antifreeze. Some new diesel trucks have a cooler in the fuel line running back to the tank, after going thru the pump and parts the fuel heading back can get quite hot. I know gas engines like cold fuel, I just thought there might be something to be gained from warm/hot diesel fuel, quicker burn, better burn, but no dice.
UAofE
Post by UAofE »
klondikekid wrote:hot shut off's, coking the oil, bearing life etc
Not an issue with diesels.
Diesel idle exhaust temp is under 300f. Gas engines idle around 500f.
If it has a water jacket its designed for either a gas engine or high performance.
Because the common rail system pumps the fuel up to 30,000psi or higher. The leakoff and return from that system is very hot. Fuel over 180f can reduce the life of the injection system.
Hot fuel is less dense. If you tune the system to not smoke when the engine is hot you will have lack of power when its cool.
klondikekid
Garrett_White_Paper_01_Water_Cooling.pdf
(601.4 KiB) Downloaded 632 times
My turbo is a garrett GT12 with water jacket, here's a little info from garrett, they mention temp. for oil breakdown etc. I see what your saying, 300 deg.at "idle", but a with a heat soak at shutdown from a aggressive ride... just seems like cheap insurance to plumb the lines,I don't mind the work installing them, A lot of talk on diesel truck sites about idling a min. or so before shut down to stabilize/lower temp to prevent early turbo failure. lot of people say don't worry about hooking up the water lines, then lot say worry about it. I'll go with Garrett's recommended install. If not hooked up, it would be a good idea to keep a close eye on oil for brake down, and regular oil changes of course.
Post by BertTrack »
In their piece they are refering to "This may seem low considering that
exhaust gas temperatures can get as high as 1800°F (980°C) in a typical high-output turbocharged
gasoline engine,"
A gasoline engine.
But it won't hurt to cool the sucker. Mind you with some taking care a turbo on a diesel will last as long as the engine does. (If it's designed correctly) (Speaking from experience)
am curious how much; if any, coolant capacity and/or improved air flow radiator you will have to increase to accommodate for cooling the engine and the turbo
klondikekid
I'm going to try running the bike with the radiator I have now, it's bigger than the rad on my Suzuki GT750 triple, and my Suzuki has never gotten hot even in slow heavy traffic in the summer. I threw a couple pics of dethmachinefab's bikes for comparison, and lord knows my bike is wimpy stock compared to his screamers.
Smart move. Keep us updated
UAofE
Post by UAofE »
Diesels have been running non-water-cooled turbos for over 50 years. The Mercedes 300D wouldn't have got its reputation for reliability if it was cooking turbos. Its common to find them with their original 30+ year old turbo.
klondikekid
UAofE wrote:Diesels have been running non-water-cooled turbos for over 50 years. The Mercedes 300D wouldn't have got its reputation for reliability if it was cooking turbos. Its common to find them with their original 30+ year old turbo.
True, point taken.
Post by BertTrack »
Also i think the gasoline turbo's will be designed with higher temperatures in mind (obviously) but this also means the exhaust turbine is designed for lower density higher flowrate gasses. That may seriously hurt it's performance on a diesel engine.
