The thought of pumping and opening and closing the bleed nipple, sent me to Halfrauds to get a bleeder.
£10 you got to be joking right? I got it anyway, and it didn't work. I took a look inside, to see a ball bearing and a spring. The ball bearing didn't seal, as the manufacture was bloody awful. Two chunks of swarf where the drill hadn't finished cutting the hole.
I got my tenner back, and thought I'd do the job the old fashioned way. Then I looked around the man cave for some inspiration.
My eyes fell on a pump spray bottle, this is what I did:
Take the pump off the bottle, fit a shrink-wrap tube to the bottom of the pump tube, and fit a 1metre plus flexible tube over the shrink-wrap and the other end over the bleed nipple.
Feed the brake some fluid, then pump the bottle top, watch the fluid travel rapidly up the flexible tubing with hardly any air bubbles. Done in a jiffy.
The 1 metre plus pipe causes a constant vacuum because it’s flexible (un like the brake parts), so sucking down the fluid.
![Laughing :lol:](./images/smilies/icon_lol.gif)
This now takes pride of place in my tool chest
