YanClone L100 fuel pump
luizbenjamin
Post by luizbenjamin »
My clone engine (186F) were intended for a generator.
I need to have lower idle speed (about 1300 rpm), now i have 2300 rpm. From what i read so far i will need to change my fuel pump. Dos anybody know what model and where can i get one in USA.
Re: YanClone L100 fuel pump
luizbenjamin
alexanderfoti wrote:You will need something like this:
http://www.ebay.co.uk/itm/Yanmar-L100-C ... 485419a7f8
This particular one it is for generator use (consistent speed). I need this: http://www.ebay.co.uk/itm/REPLACEMENT-F ... 3869601%26, but they don't ship to USA.
Oh aplogoies, I didnt know they made a different version!
Do you know what the mechanical difference is between this one and one for generator use?
I would be happy to drop ship to america for you if you cant find one in your area.
luizbenjamin
alexanderfoti wrote:Oh aplogoies, I didnt know they made a different version!
I don't know what it is the change between the two, but it is a change. I am still looking for that here, and no luck so far
I will keep an eye out, I have ordered one so I will see if it helps, I cannot get the idle lower than 1400 rpm or so.
If you cant find in the US, my offer of shipping one across for the cost of shipping is still there if you need it.
luizbenjamin
alexanderfoti wrote:I will keep an eye out, I have ordered one so I will see if it helps, I cannot get the idle lower than 1400 rpm or so.
How low you want to go? I am asking, because you can't go to low, you will loose lubrication (the oil pump in the engine likes high rpm to produce pressure).
My need it is below 1800 rpm, because of the clutch (engages at 2000).
about 800-1000.
Thats odd, as I had an oil pressure gauge on mine, and right from about 400 rpm it produces very very good oil pressure (60 psi +)
Aha, I only want it so the idle isnt silly when sitting around in traffic.
luizbenjamin
I am using this engine on a racing kart, that is why i need a idle speed around 1500 rpm, so the engine don't die if, lets say i spins out. Let me know how your pump worked, and maybe we can work a way to me get one from you.
I will keep you updated.
luizbenjamin
alexanderfoti wrote:I will keep you updated.
When do you will have your pump delivered and tested?
2/3 weeks maybe less depending on the post and the weather
luizbenjamin
alexanderfoti wrote:2/3 weeks maybe less depending on the post and the weather
There is where a found the pump that i need.
http://www.ebay.com/itm/280978098005?ss ... 1423.l2649
But like a told you, they don't ship to USA. I don't have the exactly model number, so i can check here also. Looking for "fuel pump for variable speed" didn't bring anything.
is that a fuel pump, or fuel injector that is variable orr? Looks like an injector to me.
Fuel pump :)
I received it today, and the engine ran at full rpm untill I hit the decompression lever, gave me a bloody fright.
Any ideas what I haveb done wrong, the old pump going back in also does the same thing now :(
