Im pretty sure the vibrations keep killing my fuel gauges.
I am using a gauge and tank setup from a suzuki Katana ay50. The gauges look like this:
The issue is that after having them on the bike for a while, the needle flys around randomly, but only when the engine is running, and then when its revved. With the engine off it displays the correct level. I ended up replacing one of the gauges which fixed it for a while, but then the other side started doing it. My thoughts are that the bike is shaking the gauges to bits, any thoughts?
That's a good point - the voltage on those little 50cc engines often drops quite low so it's quite possible that the instruments are driven off a regulated 5V supply...
Let us know how you get on with your fuel gauge, and maybe share your experiences fitting it. I'm sure that there's quite a few people out there, who are interested in fitting a reliable fuel gauge/indicating system to their bikes.
well, my bike is a 250 superdream, which doesnt have a fuel sender, so at the moment, I have 2 6liter fuel tanks on either side of the rear of the bike, there is 2 fuel gauges for each of them, from there, I cut out the fuel gauges from the same models dashs (suzuki ay50) and wired them up.
Realitely simple but the gauges arent that accurate, its just nice to know generically whats in each tank.
