Yanmar L100 Inside out Pictures
skoleskibe
Post by skoleskibe »
Have recently had problems regarding lack of slow tickover, and as it suddenly developed a hard knock i decided to dismantle the engine to try to find the culprit.
Aligning valve timing, three dots on gear
Cam axle
Cam axle
Vue
Vue
Big end assembly
Big end assembly
Inserting camfollowers for exhaust inlet and fuelpump, seen from a slightly different angle
Lining up ballance axle
Empty casings 3
Empty casings 3
Empty casings 2
Empty casings 2
Enpty casing 1
Enpty casing 1
skoleskibe
Re: Yanmar L100 Inside out Pictures
Thats all for now, remarkably simple and ruggedly built engine
Regards
Govenor full speed or max power
Govenor, no load or tickover
Crankcase gasket
Crankcase gasket
Fuelpump mounted
Fuelpump mounted
Fuelpump govenor leaver
Fuelpump, see the "gauge"
Fuelpump
Fuelpump
Ready for fuelpump
Ready for fuelpump
Securing crank main bearing and thereby the crankshaft
Dan J
Post by Dan J »
These pictures are really interesting - thanks for posting skoleskibe
skoleskibe
Any time, comments and / or questions are welcome. Changing fuelpump fixed the missing slow tickover, and enhanced the starting quite a lot. :roll:
Fuelpump and set of original shims was 99euro's
at: http://stores.ebay.de/Baumaschinenundmotorenshop
bought it monday morning 10.30 in germany had it wednesday at 07.15. in Denmark !! Marvelous Ebayer
Thanks for posting the photo's up skoleskibe, it will help many who have these engines when the time comes to pull them down.
A ;)
AppRenticE
Post by AppRenticE »
Thank you skoleskibe i had never got see internals of this diesel so close. infact i used to wonder why the crankcase was longy to need a chassis bodgery to fit enfields.
you got any pic of governer linking to pump :)
skoleskibe
Have a look at the pictures, the one called "fuelpump governor leaver", u can see the linkage through the oil pump mounting hole the little forked thingy, is the linkage.
AppRenticE
Got a pic of the Piston, Combustion chamber? :)
skoleskibe
sorry, no pics
regards
AppRenticE
skoleskibe
Got it, hmmm ist certainly not a Yanmar l100 or one of the flonels!!!!!!!
Regards
AppRenticE
oops.. thats of a greaves one fitted to Taurus. :oops:
