Starter Motor wiring for a 186D
Hi All
Currently adding a starter to my Chengfa and I cant figure out the wiring.
I have one battery post, and a Spade terminal on the starter solenoid.
Any ideas how to wire?
Dan J
Re: Starter Motor wiring for a 186D
Post by Dan J »
As per my previous post...
Battery post = high current wire straight from positive terminal of battery. I think from memory I used 8mm square cabling.
Spade connector = low current connection via a suitable, switchable source - suggest tap a line from your "ignition" system (e.g. one that is only on when the key is on - e.g. a feed to the horn or brake light switch), feed through a starter push switch and then to the solenoid.
Both earth through the metalwork and so you must have similar spec cable as went to the starter back to the battery negative from somewhere on the engine.
Dan J wrote:As per my previous post...
ahh Thanks - I wasnt able to spot the wiring info in the previous post, thanks for your help :)
