Here's a picture of the 50 percent finished instrument cluster for my Daihatsu powered bike. The speedo and tach are programmable. The OEM crank pulley hall effect pickup will be used for the tach and a signal generator will be attached to the speedo cable for the speedo. Indicator lights are also VDO. I'm currently fabricating the lower piece of the instrument bezel, to be welded on. The housing in the picture is just a piece of sheet aluminum painted flat black and wrapped around the unit to give you an idea what the finished unit will look like. Hopefully another week or so to finish the unit.
[img=http://img262.imageshack.us/img262/8020 ... 5np.th.jpg]][/url]
Avery
VDO Instrument Cluster
