Enfield gearbox pulley
Post by Anorak_ian »
I don't know why I didn't see this before, here's a pic of the flitzbitz showing it's belt drive.
I was wondering if the pulley on the Enfield gearbox was a one off or an off the shelf job. Anyone know?
Belt Drive
It's an easy one to answer - Hitchcocks catalogue.
I think Sommer sells them in Germany too, Peters bike has the belt drive too and the craziest primary cover - amazing what you can do with a CNC laser cutter.
http://www.warham6173.eclipse.co.uk/Die ... y%201.html
Piccie is about 2/3 down the page on the LH side (the red one).
Regards
Hi Dave, thanks for the info, is this catalog on line? Only I can't see it.
Just incase were at cross purposes here, it's the back wheel to the gearbox sprocket / pulley that I'm looking for.
Ian
huub
Post by huub »
if you can find someone with a lathe it is easy to remove the teeth from the enfield sprocket, and the outside of a belt sprocket over it.
bolt, or weld it in lace, and you end up with a belt sprocket that fits a enfield.
i did it a couple of times for a commando belt drive.
cheers,
hubert
