a way to test governor set in on yanmar 406?
schatz
Post by schatz »
Hi all, I have another question from my dad. Hopefully he will have his account set up soon.
"I have a new yanmar 406 engine. the governor allegedly sets in at 3600 rpm. Does anyone know of a way to test this? Is there a component one can buy at a realistic price that can either pick up the rpm off the crank or somewhere mechanical? or pick up the pulse on the diesel injector pipe?
on my initial few road tests I have had a complete lack of road speed and the governor has been cutting in at an accurate speed of 45mph, will this free off and the speed build up, or have I got a problem? if anyone has any ideas I’d like to know as on reading the manual, resetting the governor is off course a nightmare betwixt engine and gear box."
Govenor Setup
You can buy a laser tacho - I got one from Hong Kong via Ebay for under 20 quid.
For a more perminant tacho you can't beat a 'Tiny Tach', as you suggest this picks up the pulse from the high pressure injector line - I have one fitted to my Enfield and I know that Dan does too on his Yanma.
Your looking for the springs to exert the maximum force on the regulator arm as 3600 is the maximum designed speed - I think Andrew Waust in Aus has a nicely loosened up Yanma that he takes to 4000 rpm on occasion.
Hope this helps -
dieselbikin
Post by dieselbikin »
Join Diesel Motorbike World at Yahoo groups and go to its files sections. In the Yanmar engine section you will find several excellent papers explaining the operation of the Yanclone governor. Next download the Yanmar service manual and go to pages 66, 67. You will see which holes to put your springs in.
http://autos.groups.yahoo.com/group/Die ... ike_World/
While you’re at it, join the Diesel Motorcycle Yahoo group. Look under files to find the best Excel rpm/ratios/speed spreadsheet around
http://autos.groups.yahoo.com/group/DieselMotorcycle/
Also try http://diesel-bike.com/cgi-bin/yabb2/YaBB.pl .
These sites have a many useful files and pictures.
I personally use a Sendec rotating shaft tachometer that measures off the crank. I'm very happy with it. I had a Tiny Tac and it didn’t work for very long. Some people have used a $10 bicycle computer successfully.
http://www.sendec-products.com/index.ph ... Itemid=136
http://www.reuk.co.uk/Use-a-Cycle-Compu ... ne-RPM.htm
http://diesel-bike.com/cgi-bin/yabb2/Ya ... 1222727228
http://diesel-bike.com/cgi-bin/yabb2/Ya ... 1165684172
1980 Suzuki 550
10 HP Yanclone
94C Comet
I don't frequent diesel-bike.com anymore, I'm fed up with reading and not being able to register.
schatz
Post by schatz »
thanks for the excellent suggestions! I follow up the links and pass on to my dad. thanks again!
