Hi all
To get the clearance I need for my clutch basket to clear my chain, I have flipped my gearbox sprocket around.
One side of the sprocket has a ridge on it like this:
One side is flush, and the other side has this ridge (that maybe sits proud by 5mm)
Normally, I assume the ridged side sits facing the gearbox, I have flipped it so it now faces the clutch (so that the chain sits further in, closer to the gearbox).
Can anybody see any issue with this?
Gearbox sprocket?
Re: Gearbox sprocket?
Just check that the chain doesnt hit the gearbox casing, especially if you are going to run o ring chain. Also check the chain allignment
Phil
Phil
A OK on the gearbox clearance. Am also not running an o ring chain so good on that front.
The main reason I had to flip it was becuase I couldnt get the correct alignment with the rear sprocket without doing it.
I will test it quickly and then pull the clutch off and make sure it doesnt rub against the casing.
