Can anybody offer an answer to what output the alternator has on the 1B30 hatz 14 volts I assume but what amps or can I remove the + wire from the battery and pop an ammeter in line would that work ?
Thanks Nick
1B30 Hatz alternator
- henneberg
Re: 1B30 Hatz alternator
The ammeter popped in the +line between the battery will do, but the current depends on the charge state of the battery.
Instead of the battery, better use one or more H4 bulbs, like 45 W bulb consuming ~ 4 amps @ 14 V
The alternator output voltage should be measured at same time.
![Image](http://larsenhenneberg.dk/pictures/Erik_avatar.jpg)
