Dry Sump
Dry Sump
anyone considered dry sumping their engine (not counting splash fed of course)
1. Could increase your ground clearance
2. Would let you lower your engine for better CG
XLerate
Re: Dry Sump
Post by XLerate »
Yes, I mentioned it in another thread. In addition a dry sump system completely protects from oil starvation at extreme lean angles.
Beyond just a dry sump, adding a pre-oiler will virtually double the life on an internal combustion engine. 90% of engine wear throughout its lifetime occurs at startup, when the pressurized oil isn't there to separate & protect bearing surfaces. A pre-oiler has a cannister that is pressurized by engine's oil pump by tapping into oil galleries, with a solenoid valve at inlet/outlet. At shutdown the solenoid valve closes, trapping pressurized oil in cannister. At startup the solenoid valve is energized to open, dumping the pressurized oil through oil galleries & bearings right before engine ticks over: full protection!
A very inexpensive way to double engine life.
Quite simple to build and several references online, such as Accusump. Not all that expensive to buy either.
