peugeot-guzzi
Nanko
peugeot-guzzi
Post by Nanko »
Bike is on its wheels ! temporary , just to check how it looks and feels.
Till now I am happy with the result ,the bike is in spite of the heavyer engine easy to manouvre ( and i am not the Hulk)
Pictures on : http://home.planet.nl/~andra015/dieselbike.html
Nanko
Hi Nanko
Looks like things are coming along really well. Now who said you couldn't fit a 4cyl diesel in a bike frame? That is going to give you all the torque and power you need. What sort of gear ratio's are you running? guess it will be very tall.
Another great diesel bike project nearing completion.
Andrew :wink:
Nanko
peugeot guzzi
Post by Nanko »
andrewaust wrote:Hi Nanko
Andrew :wink:
Hi Andrew
I am using a 850T3 gearbox and Hydro convert final drive
With this combination the bike runs 120 km/h at ~3100 rpm
theroretical top speed ~190 km/h
Byrdman
Post by Byrdman »
Awesome Nanko, it looks great.
balboa_71
Post by balboa_71 »
Nanko,
That's gonna be one kick-ass bike!!! How'd you figure out a way to adapt the engine to transmission?
Cris
2006 Jetta TDI for road work.
2007 Bonneville
Nanko
Post by Nanko »
balboa_71 wrote:Nanko,
Cris
Hi Chris , simply by mounting the GUZZI flywheel on the PEUGEOT engine .
Now the original guzzi clutch can be used and also the starter motor can stay in the same place.
Started with the gas tank today , chopped the lowerpart from the original tank ( that hurts ! )
With a new bottom I still have appr. 17 liters fuel capacity left.
Nanko
Nanko, Awsome looking machine my friend. Do keep us informed as to how things go with the project :D
balboa_71
Post by balboa_71 »
Nanko,
I'd never thought of mounting the guzzi flywheel to another engine. Figured every engine requires a flywheel designed for it.....goes to show you how one can get tunnel vision (in my case) over the years.
regards,
Cris
2007 Bonneville
Nanko
Post by Nanko »
regards,
Cris
Hi Cris
Ofcourse every engine needs a specific flywheel , and I am not sure at all if the GUZZI flywheel is heavy enough to let the diesel run well at 1000 rpm
But there is space on the circumference for some extra kilo's
Nanko
greg123
Post by greg123 »
Looks like a 1529cc Pug/Cit TUD5 Iron block, that correct? What you hook it out of? Lucas/CAV pump? How did you get the gearbox to bolt up? I have built tons of these engines in the past, mainly in AX's - great motor save for alloy block troubles (and on the iron the poor oil sealing on the no1 cyl end causing oil leaks between block and head).
Great stuff, 50-60hp should do good! Though with a torque converter if I understand correct it will dump a load of diesel into heat and mute your mph/mpg, unless your converter has lockup.
Greg.
Greg
Freelance Mechanic specialising in vegoil conversions and VW TDi engines
Nanko
Post by Nanko »
greg123 wrote:Looks like a 1529cc Pug/Cit TUD5 Iron block, that correct? What you hook it out of? Lucas/CAV pump? How did you get the gearbox to bolt up? I have built tons of these engines in the past, mainly in AX's - great motor save for alloy block troubles (and on the iron the poor oil sealing on the no1 cyl end causing oil leaks between block and head).
Greg.
Hi Greg
It is a TUD5 , with a BOSCH pump, and the engine came from a CIT. SAXO.
I know its bigger brother TUD7-9 occasionally has a oil leaking head gasket , I was not aware the TUD5 has the same habit :-(
The gearbox is attached with a 15 mm alu. flange at the engine and 8 spacers between flange an GUZZI gearbox.
Later these spacers will be replaced by a alu. ring to make it more or less water/dirt proof.
My fist idea was using the GUZZI hydro covert torque converter , but (top) speed would have been 140km/h @ 5000 rpm.
With the 850 T3 gearbox and hydro convert final drive I will get 120km/h @ 3100 rpm
Nanko
Nanko
Post by Nanko »
Bike had its first test drive , and I am very happy with the result.
Lots of bottompower , very quiet engine even without sillencer.
Next step is getting the bike properly registered .
See: http://nl.youtube.com/watch?v=q0JJCPUgnIQ
Nanko
LocomotiveBreath
2 Thumbs Up!
Post by LocomotiveBreath »
I just had to look at your video, wonderful, looks like lots of fun. I posted a comment and gave you 5 stars!
You did good!
Pug Guzzi
Nanko,
I too have just watched the video and it is very impressive :D
That bike has a good turn of speed :!:
It would be good to see it in Hamm this year if you get it registered in time.
Nanko
Post by Nanko »
Nanko
Re: Pug Guzzi
Post by Nanko »
Stuart wrote:Nanko,
Stuart , I will be there anyway , with or without the dieselbike .
Hamm is only 200 km from where I live , would be great to see all these bikes and meet their owners!
Nanko
Hopefully I too will be there and will say hello 8)
balboa_71
Post by balboa_71 »
Nanko,
Really nice job on the bike!!! Just goes to prove that diesels are hard to beat.
Why can't the bike industry give us this technology?????
Cris
2007 Bonneville
