Hello!
After trying to machine the original sprocket down at my university workshop (what failed, the stuff is to hard for our equipment) I'm gonna buy a new one.
But what are the specs of the sprocket? I's there a standard thickness toothdistance and so on?
It must fit the yanmar axle (25 mm), were did you guys order the sprocket?
thanks!
Travel
specs of the primary
- DieselFly
Re: specs of the primary
Try a ceramic cutter should do the trick
travelcrazy wrote:Hello!
thanks!
Travel
Finished and riding 1975
CB500t Turbo Punsun powered
hardtail.
hardtail.
It's 3/8" duplex. But why don't you just take the sprocket to a decent hardware store? I got mine at Laman. Are you sure about the 25 mm? Isn't it 1"?
Hello,
Jep it's 25 mm and thanks for the info. Let's search for a shop that sells it. I'll try to find it local but we'll see.
almost done, wel untill the next problem
Thanks
Thanks
