I have been looking around for an engine for a while (Cornwall isnt very good
Outside I have a Petter AVA1 diesel.
I think its rated at 4.5bhp @ 1500rpm (I would need to check)
I am just wondering about using this engine for a diesel bike.
If I geared the drive from the engine to the gearbox, at a 1:2 ratio, it would be roughly a 3000rpm equivalent.
Its definately got enough torque to pull it, they use the AVA1 and the water cooled version the AV1 to drive canal boats etc...
Its got a nice big cast flywheel, and I could fiddle with the governer and adjust it, so it only worked as a max RPM lever.
It wouldnt be very fast, but thats not important...
I am thinking you see, about building a modern diesel version of the Trojan Trobike (lovely little old bike
I have been planning to build one for a while, whether its a petrol or a diesel, as I can shove it in the boot of the car, on a long journey (visiting relations for example) and then use the bike when I am there
Any thoughts?
P.S. I know the engine is heavy but I am not too worried about that, as lifting into the car can be aided by a length of wood
