Finally :)
IgorVigor
Finally :)
Post by IgorVigor »
I have finally got an engine for a diesel bike/trike build :)
Its a bit bigger that what I originally was thinking about though :S
I was hoping for something in the 10~25hp range with 1 or 2 cylinders...
Instead (through an unfortunate turn of events) I have got an engine..
Its a Ford 1.8 Endura Diesel with van 5 speed fwd gearbox, producing 60hp...
I'm not sure what I am going to build with it yet though...
I am thinking a trike with 2 front wheels might be a good idea...
As much as I would like to build a bike with it, I'm not sure the best way to get the power to the back wheel...
Welding the diff is an option, but I would need a shafty bike as a donor...
So has anyone got any thoughts/ideas/comments?
IgorVigor
Re: Finally :)
Post by IgorVigor »
I must admit, I do like the old morgan style reverse trikes...
http://cycle-car.com/
If you want something of that style, there is the Lomax kit car...
Based on the little old Citroen 2CV...
Not sure if many (any?) got to the states :S
EDIT:
Still want a diesel bike tbh...
my current idea, as to making it fit, is to chop a bike transmission off a donor bike, and then mount the ford diesel transversely into the frame.
Then use a primary drive chain to the gearbox... All I would have to do, is to remember I need a roughly 2:1 ratio from the engine to the gearbox (so 4500rpm at the engine is 9000rpm at the gearbox)
Or else the bike will struggle to do 60mph :P
Just need to get the engine out of the van now...
Then I can have a proper look at the crank/clutch assembly...
Re: Finally :)
IMHO with that big of an engine you might want to go CVT to reduce overall space compared to your present plan.
IgorVigor
Re: Finally :)
Post by IgorVigor »
Thing is, is I wanted a chain final drive (reason being, I have a bike that would be modifiable for this purpose, and I haven't got the money to buy a different bike)
I do see what you mean though...
The logical answer is to use the engine (and possibly gearbox) for another project of mine, and wait until I can get a smaller diesel for a bike :(
the problem though, is I like mad projects :P Still toying with the idea of a custom built turboshaft engine running on diesel for the bike :D
Would that still qualify as a diesel bike on this forum? :P
