A New Diesel Bike Is Born
LocomotiveBreath
Post by LocomotiveBreath »
My new bike, it's either a Honda CB954-D, or a Hoggerini. What do you think, my first attempt with my one speed Centrifigul Clutch experiment.
http://img155.imageshack.us/my.php?imag ... 048ja0.jpg
http://img175.imageshack.us/img175/8558/dscf0050cl6.jpg
Last edited by LocomotiveBreath on Tue Apr 03, 2007 1:19 am, edited 4 times in total.
:D Nice work, Dave :D For what it's worth I think 'Hoggerini' has a much better ring to it :)
Byrdman
Post by Byrdman »
Very nice.
Does the diesel oil pan sit at about the same height off the ground as the stock engine?
LocomotiveBreath
Oil Pan
Hello Byrd,
Yes, I will have plenty of clearence. The Honda engine sat below the lower frame rails, and the Honda exhaust was below that. She fits in really sweet. I see a ground clearance of between 5.5"-7". Also I'm almost sure that there will be a weight savings as the Honda engine/transmission weighs equal if not more than the Ruggerini w/clutch-jack shaft.
Last edited by LocomotiveBreath on Mon Apr 02, 2007 5:36 am, edited 2 times in total.
Byrdman
Re: Oil Pan
Post by Byrdman »
LocomotiveBreath wrote:I see a ground cleaence of between 5.5"-7".
Awesome, you can use it as an adventure bike then! :D
When you get it done, ride it to Chicago would ya. I want to give it a spin.
Hi, could you just clarify how the transmision you plan to use works? I see your centrifugal clutch will transmit via tripple Vbelt. You talk about a jack shaft, I think we would call it a leyshaft.
regards SAM.
LocomotiveBreath
Jack shaft, leyshaft, layshaft
I will place the Jackshaft/leyshaft behind engine, I'm looking at pulleys/sheaves 6.3"-7.7" diameter, and keeping the stock 50 sized sprocket located at or near the stock location. Gearing it @ or near 70-75 mph @3600 rpm
The Ruggerini RD211 (954cc) makes 40 ft'lbs torque and 33 ft lbs @ clutch engagement of 1400 rpm.
And a Layshaft is the handled shaft on an EMD powered locomotive that over-rides the throttle, used on start up of the prime mover on the locomotive.
I used to be a Railroad engineer for a time for the YSL railroad (1992-1994) I'm very familure with #131's layshaft as #132 and #133 were still not in an operational state. The 44 ton locomotive (#50) had 2 ea 250hp cummins engines, I also did all inspections and repair on the railroad, locomotives, and cars, we had 4 full time people, 27 miles of main line and my garage was our fabrication shop.
http://www.youtube.com/watch?v=MTKYZGeXgJw
http://ncespee.railfan.net/rosters/yslrtxtros.html
http://www.trainweb.org/chris/Yolo.html
See Layshaft: http://www.freepatentsonline.com/5265567.html
