Just found some details on power losses for small diesels associated with heat and altitude.
2% reduction for every 5 deg over 20 deg.
1% for every 100m above sea level
On top of this individual motors vary by 5%.
So my lowly 9hp Lombardini could be just 8.55hp to start with, as London has hit 30 deg this last week this robs a further 2% leaving just 8.38Hp to push along with.
Makes you think about those planned adventures - crossing the Pyreneese fully loaded with just 5.87hp left (3000 metres) might mean a fair amount of time on first gear.
Right - where did I put that little turbo!
Power Losses (temp & altitude)
Re: Power Losses (temp & altitude)
Need more watercooled small blocks, for Enfields etc. Another plus is that they should be less noisy.
When I toured th e pyrenees 3-4 years back I was surprised how fast it got cold going up those mountains. varied from 30+c to 6c in matter of minutes, so there may be a little bit of temperature compensation for altitued
Bugger No trooping over the Barrington mountains for me then when the temps hit 40deg . I can see it now, drag racing the tourist buses up the hill, heaps of black soot wondering if first gear will be low enough !!!!!!!!!!!!
Hmm didn't notice it in the Alps.. With passenger and luggage you have to shift back a lot in the mountains..
After a while you don't have a good sense which inclination is bigger..from 3 to 2nd.. no worry
Lots of torque, no heat problems..
I think it's important to keep it revving not too low and shift back in time.
We plan to go at the end of this week.. wherever it is sunny..
