hi guys
thinking what engine i will fix in my old harleyframe ihad now 2 years, i called my kipordealer in germany what exist new. because lombardini is sure the best solution but i dont like to pay again so much money.
i have now 2 bikes with that engine.
he said me , it exist an new 3 zylinder turbo with under 1000ccm.
price officiel is 2900euro but i get it cheaper sure.
now i wait for pdf with all data.
the weight is 92kg komplett, but you can put thinks away that you come down 10kg.
here to see
http://www.wm-motoren.com/index.php?opt ... &Itemid=52
but only from one side.
and he will look if its possible to put generator under flywheel.
dont worry engine runs 3600ump and has much more power. so i still wait for answer.
if sombody want we can order more and price go more down.
i will take two, one for me and one for one custumer, when all messure is good for me.
heiko
kipor turbo 3 zylinder
- LocomotiveBreath
http://www.dieselbike.net/daihatsu.htm
Yes, That engine fits very well in a Harley, I had one in my Dyna Glide for awhile,
See: http://www.rbracing-rsr.com/lsr21/supercharged.html Scroll down
Good Luck,
Good Luck,
Re: kipor turbo 3 zylinder
Hello Heiko,
Do you have any news about this engine?
There is, a friend of mine thinking about building a Diesel engine in a Ural Frame.
best regards
Hans
best regards
Hans
May the Source be with you!
hi
yes now i know that kipor dont want to sell that engine under their name.
they will build it so i think but only for daihatsu or briggs.
so if we want that engine we must buy there.
heiko
heiko
Heiko I plan to use one of these engines purchased under the Briggs name. If their is anything I can do to help you get one let me know.
