im back....
SUMO
im back....
Post by SUMO »
after a LONG time in the corner of the garage gathering dust im back to the diesel bike
i could do with a little help on something though - battery - the old one on the donor was a 12v 68ah. its bloody huge. any ideas if there is an alternative for something physically smaller?
i was wanting to put the tank under the deat in the gap but the battery will easily fill that [if i can get it in there even!!]
arnaud
Post by arnaud »
Wow! it looks interesting! do i see ural front wheel and gearbox?
What can you tell about the frame and engine>?
where do you need the big battery for. Isn't kickstarting an option?
SUMO
Post by SUMO »
here you go - all posted on here before but its been a long while since it got side lined so a brief catch up....
basically a hacked ural with a d950 mated in there
http://www.vintagechop.com/VC/Diesel_Bike.html
Crazymanneil
Post by Crazymanneil »
What about one of these? -
http://www.tayna.co.uk/ODYSSEY-PC680-P3107.html
There are other sizes too or else put a couple in parallel? Depends what sort of oomph the engine needs I guess. Not cheap tho admitedly. My last diesel car battery was only £50!
Neil
johnfireball
Post by johnfireball »
Hi Sumo,
have a look at this, its using a 36AH battery which should suffice
http://www.extremedieselbiking.de/pics/ ... ernot1.jpg
John.
SUMO
Post by SUMO »
Crazymanneil wrote:What about one of these? -
Neil
found them last night thanks for that - they are dear but small so ill pay the extra, there is one that will sit on top of the swingarm pivot and fit nearly flush with the front of the tube so take basically no space leaving the rest open for a tank
Crazymanneil
Good stuff. The Odyssey should have the cranking power to turn the engine over no problems, but just not for a long time. So long as the engine fires :). The documentation makes some impressive claims like the battery can operate in extreme cold etc so it should be a decent job.
Neil
