6 speed enfield
6 speed enfield
i dont want to withheld the fotos from my new small projekt.
i fixed for an coustumer in his enfield the 6 speed ultima gearbox in an enfield frame with the 505ccm lombardini engine. i am strained how it runs with 6 gears.
but first i had to make the alu primärcover and brake.
heiko
heiko
- taildraggin
your questions
the gearbox runs much lighter than the 4 speed box from enfield.!
and it runs with oil and not with grease.
the teth of the belt is 8mm the broadly is 4cm.
but you can make it smaller too.
heiko
heiko
- taildraggin
Is that right side drive you are thinking of? Where the final chain/belt drive comes out the other side of the box? I've never seen one of these admitedly - there is not much in the way of a harley/parts scene over here.Sphere wrote:Don't those ultima boxes come in both rhs and lhs flavors? Just one is 100 bucks more expensive? That's what I gathered from browsing ebay.
Neil
- taildraggin
The shifter comes out the left side of a harley gearbox and it's meant to go to a (left side) shifter linkage, which could be adapted (on the frame) to cross over - like the late model Enfield rear brake or somesuch. Not to keen on that.
And, Heiko could probably tear apart the gearbox and fashion a shaft out the right, but...
The right side drives are for the super-wide rear chopper tires. Otherwise, they have to offset the engine in the frame to clear the wide tires. I'm no sure that matters for our purposes. The linkage remains in the stock position.
BTW: Heiko, did you have to grind off the starter mount on your Ultima?
What's great about this is you can use the new unit-motor enfield frame with this gearbox, not to mention other small bikes.
The gearshift is peeking up on the far side of this picture of the RSD:
DOH! I see you've cut the starter plate away on the tiger too - I wondered why it looked such a neat job!Heiko wrote:hi
yes i cut all staff what was for the starter.
its in way .
yes all enfields you can build with that gearbox without changing frame but its much work.
but all here must like work because off driving a diesel bike. it always somthing to do.
ciao heiko
This means that the chain primary I have might not work for my application. The chain case comes right to the back of the starter plate. I guess time will tell when I set everything up on the bench.
I guess getting the engine running would be a higher priority though!
Neil
movie
here i put an movie of that ready enfield in youtube. its that 6 speed gearbox with 505ccm ruggerini engine.
http://de.youtube.com/watch?v=gOA7qdjY-dI
heiko
heiko
yes its from vdo.oilburner wrote:Are you using a VDO drehzahlmesser electrische? How do you generate the signal?
Thanks
the signal is W like from an generator from car.
you can buy regulators from hatz or lombardini with that connection.
in back of vdo drehzalmesser is an small screw there you can make it simelar to the real idle.
i hoop it helps you.
heiko
many thanks for your compliments.oilburner wrote:Heiko, I forgot to compliment you on your excellent workmanship and well designed diesel conversions. I am particularly impressed with the clean factory-like appearance and high quality custom parts. Thanks for sharing information with us and good luck with your future projects.
