.. Satrting is okay, power is okay,but when riding at a steady speed, the engine is running a very little 'uneven' like you have rhithemmacally strong wind ahead.
Also acelleration is a little uneven.
The chain and sprockets need to be renewed, for this i have to remove the primary drive.
shall i also remove the dieselengine-left cover to replace the flywheight system?
Anyone an idea what else could be thje cause?
little uneven running winsun 188
Re: little uneven running winsun 188
No one?
Maybe too specific diesel knowledge for the enthousiast here?
Besides the flywheight system, could it be the wear of the pump ityself?> giving not exactly the same amount of fuel every time?
Solved it, worn out chain/sprockets were at fault.. Thought you would like to know for whgen you are encountering something like this..
