Daihatsu Briggs and Stratton 3cyl Industrial Diesel Turbo Manual (not Charade).
Links to Diesel Engine Manuals available online
Manual - PDF
http://www.dieselbike.net/manuals/Daiha ... manual.pdf
This PDF is report by a University team doing a snowmobile economy fuel competition.... in it is discused upgrades to the engine. Posted originally by Coach.
http://www.mtukrc.org/download/buffalo/ ... r_2011.pdf
henneberg
Re: Daihatsu Charade 3cyl 993cc Diesel Turbo Manual
Post by henneberg »
Thanx, nice to have just in case an engine shows up ,
They are a bit thin on the ground aren't they...
henneberg
Post by henneberg »
They are hard to find "just around the corner"
doddy
Post by doddy »
henneberg wrote:They are hard to find "just around the corner"
I have two, around a few corners and over at least two seas!
Turns out it wasn’t the Charade manual. Title of thread modified. Let’s hope one turns up.
Post by mark_in_manchester »
Posted by Mark before we realised the manual we linked to wasn’t the Charade book.
I just spent a while looking at this manual - it's a great resource, but it's for Daihatsu / Briggs & Stratton 3cyl industrial engines as are used on some big mowers etc. The engine here is a pushrod job with no balance shaft, whereas the Charade engine is OHC and has a balancer. I would guess that some parts are in common (I've not checked bore and stroke, for example - the inj pump looks similar but is not entirely the same, and the turbo is rather different though this manual will be useful for principles).
My charade engine manual is glued together, not stapled, which would make it a right boring fecker to reproduce. But hey, I guess I should get around to it.
Thanks for pointing that out Mark. Changed the title name.
