.. in building a yanclone with the priceparts subframe and inner primary, i am busy for many ours shimming the engine so that the gearbox shaft can spin- more or less- freely in the inner primary bush bearing..
Not any progress so far,,
once setting it okay, fastening the 4 bolts, secureing the engine and there's a lot of strain again on the shaft..
can anyone give me a tip? or is the a ball bearing possible in this place?
Trouble fitting the pricepart inner primary
