Diesel Dnepr with Hatz 1b40
Hi! I am working on new project, Dnepr with Hatz 1b40 diesel engine, not much to say, but already have something to show:
https://www.youtube.com/watch?v=SNNEJ8rtZd8
upcoming further updates!
Re: Diesel Dnepr with Hatz 1b40
Looks good. Keep informing us.
Alex
Alex
Excellet work. Can't wait to watch your progress on this one. Do keep us posted.
- Tetronator
That's a nice clean build he's got there, did he also use the dnepr flywheel?
Is that an Ural 18 inch front wheel on there?
yes flywheel is from Dnepr, front wheel from Ural but its 19 inch, rear fender also from Ural, front fender IZH planeta, gas tank obviously JAWA, spring-loaded seat IZH-56, rest is dnepr
- Tetronator
Must be the tight fender that made me misjudge it, Aren't the Dnepr brakes better? Because those have dual leading shoes, right?
Looks good tough.
Looks good tough.
right! but those are dual leading Dnepr brakes
- Tetronator
I see.
So Dnepr also has single leading brakes, is there an easy way to keep the 2 apart? And does the dual fit into the single wheel hub?
- Tetronator
Allright! This will really help when I decide the stopping power isn't enough with the stock K750 brakes. Thanks!
