But I thought I'd put it up here - it makes sense to me, but I wonder if any of our more experienced people can check and see if they agree
http://www.buggiesgonewild.com/big-bloc ... ource.html
L= ((2*a*D2+2*a*D1)*Pi+D2^2-2*D1*D2+D1^2+8*a^2)/(4*a)
a=the center to center distance (distance between the center of the bolt holding on the drive and the bolt holding on the driven.)
Pi= if you don't know what this is, where in trouble.
D1=The Diameter of the drive clutch with the belt wrapped around it. Measure with a cheap dial caliper.(the belt is important because all belts are measured by the outside circumference not the inside)
D2= The diameter of the Driven Clutch with the belt wrapped around it. An easy way to measure this is to take it off the cart lay it on the concrete and mark it's diameter (with the belt on it) with a pencil then measure the distance between the marks with a tape.
