No small engineering feat. It appears he capped the cylinder base on a donor engine to use the transmission, with a belt drive through the crank replacement. And then adapted a right angle gearbox in lieu of a sprocket for the final drive.
http://www.youtube.com/watch?v=uGEaVh64 ... j-2cz3Ayjw
http://www.youtube.com/watch?v=ih8yjGZDBdU
Thai Build
Thai Build
albertaphil
Re: Thai Build
The right angle gearbox appears to me to be the differential from a quad. Of course if it's truly a differential then the builder would have had to weld it or otherwise lock it.
What kind of engine is that?
