Ural/Dnepr Frame dimensions
Tetronator
Post by Tetronator »
Hey guys!
I was wondering if anyone has frame dimensions for any ural's and/or dnepr's specifically;
-Space between the 2 frame rails going up to the steeringhead (downtubes? :? )
-Space between the 2 lower frame tubes.
-Height between upper frame tube and lower frame tube
-Height diffrence from the lower frame parts to the center of clutch plate/flywheel/crankshaft axle if the gearbox is in its original position.
-Space between gearbox and 'downtubes' and the front mudgaurd.
I want to find out if one of these http://www.romotech.nl/motoren/luchtgek ... toren/25ld would fit in an unmodified frame.
Estimates are welcome too!
I found this one but it has a modified frame tough I do not think that was needed.
Bretts Dnepr Lombardini Diesel Motorcycle
Honda VT600 C Shadow
H̶o̶n̶d̶a̶ ̶C̶B̶R̶6̶0̶0̶F̶2̶
Mercedes-Benz W123 300D Sedan
