Flywheel turning
Flywheel turning
I have had a spare flywheel lying about and I have just dropped it off at my friend machinist who is going to turn it down for me.
It currently weighs 9KG, I am aming for 4-5KG, so lets see how it fairs when its done.
Re: Flywheel turning
Post by Anorak_ian »
Fingers crossed.
Just got the flywheel back.
Due to the profile of the flywheel, which is like this if you look at the side:
I wasnt able to take too much off without affecting the structural integriy, as all the weight is held on the rim with a thin connecting peice in the middle.
I was left with this:
It weighs 6.7 KG compared to 9.00kg of the original. I have just fitted it and from brief revs the engine seems quicker to rev, I should have a chance to take it out tomorrow and see how it rides!
Post by tappy »
As long as it idles OK I should think it improves the ride no end.
Any update?
Had a long ride today.
Broke a gearbox mount weld so im going to beef that up tomorrow.
The engine revs more freely and is a tiny bit faster through the gears. Gear changing however is much nicer as the revs come down quicker when changing gear.
The idle has been completely unaffacted.
alexanderfoti wrote:Broke a gearbox mount weld
More torque due to a faster acceleration?
More like my bad engineering/welding. The mount has broken 4 times in the past.
