If you own a Belstaff Jacket then you'll likely to suffer with the same problem that I did regarding the belt. These always twist and when you come to buckle up they are not easy to sort when you're wearing the coat.
I acquired some stiff copper wire (just over 2mm dia if I recall) and, using a braddle, managed to inset two lengths into the belt loop/holders. I had to shape the wire into something circular before I succeeded in getting them all in.
Once in I was able to straighten them, crease them and then press them flat.
Now the belt is unable to twist through 180 degrees and cause me a problem. It does still bunch a bit but nothing I can't pull straight without having to remove the jacket.
My jacket is not of the wax cotton type but of the newer artificial fabric type.
Belstaff Jacket tip
Belstaff Jacket tip
Eddy Wane
Re: Belstaff Jacket tip
Mentioning the waxed Belstaff brought back a memory of when I was 16/17 riding in all weathers. I came home one night freezing cold and I stood my jacket up in front of the fire and watched it slowly sink to the floor as the frozen wax melted. A few of my mates had the same jackets and we used to zip them to each other to form a circle. (Ah the mind of a child).
The worst thing about the waxed jacket is that it made shirt cuffs black.
As for the belt I just tied it back on itself and use it as an adjuster just like I do now with my modern Goretex kit.
Just had a thought - Who remembers the RAYOVAC rotating visor? Now then where did I put my glasses, I had them a second ago.
The zip broke on my Belstaff & it wasn't totally waterproof so I'm getting a new zip fitted, washing it & selling it on. It cost £350 & is a tough jacket so hoping to get £100 back on it? We'll see.
Hard work removing the patches! All places I've visited on various diesel bikes too, of course
But some were transfered from a previous jacket.
