Rhynri wrote:That's what happens when you let an engineer name something.coachgeo wrote:Assume you mean Drive clutch or Primary Clutch. The terms are confusing. Driven is the Secondary clutch. as in it is "driven" by the primary/drive clutch that is spun via the crankDieselFly wrote:.... Looking at your pictures you may want to install you driven clutch first as your drain tube looks like it will hit where your turbo is mounted....
I tease, of course. Yes the terms are very confusing.
Diesel Single Bobber Build
- DieselFly
Re: Diesel Single Bobber Build
Lots of beer helps
Finished and riding 1975
CB500t Turbo Punsun powered
hardtail.
hardtail.
Here's the bike mentioned previously:
http://www.bikernet.com/pages/The_Notor ... ammer.aspx
1980 Suzuki 550
10 HP Yanclone
94C Comet
10 HP Yanclone
94C Comet
- DieselFly
Looks good so far. Its amazing how much these little turbos whip up the oil. If you can use a piece of copper tube or something like it on your turbo return it will help dump some heat out of the return oil
radicalnegative1 wrote:Latest development:
http://www.youtube.com/watch?v=Fwfe4LhJDqY
Does everything look ok?
hardtail.
hardtail.
Once I get a driver/driven combo I'll cobble up a more permanent oil return line.
I also did the PCV valve modification described by some guy on YouTube. Pretty straightforward, actually. Everything came out great.
Next is the plenum chamber.
- I'm pretty new here..
updates!?! Spring semester is almost over!
Right.
So the bike has been home in Ohio for all this time, and, unfortunately, I go to school in Alabama. So I haven't been able to work on it except for over breaks.
The good news is that this week is exam week. So after this week, I'll be heading home and get this thing finished.
I'll kick it into gear once I get back. I'll have a full-time job/internship thing, but since I'm living at home, I should have plenty of time to work on it.
Here we go - some updates finally.
I can't weld well. I'm working on it, but I don't trust my 'skills' at all. So I've been saving up money and went with a custom frame builder, Cycle One Manufacturing, to build me a frame.
So is that big yellow rimed wheel sitting in front of the bike going to be the back or front tire
- henneberg
Hi, looks nice so far, keep on realizing your ideas
Just a shot of a rideable mockup I did over thanksgiving. So much more work needs to be done, but progress is being made.
- I don't post much...
Any updates?
