Did my first engine run test on a Punsun V2 in a Dnepr frame build. Everything went according to plan, even my self designed mechanical engine kill switch and idle adjustment system worked.
However the starter really has to work hard, and as I'm told the original non geared started is not known for it's reliability I was wondering if anyone has the valve rocker covers with the compression release switches? Mine do not have them. Perhaps there is someone out there with eg Punsun with failed crank that might be interested in selling his rocker covers?
sno-bro
Punsun compression releases
