Hi all
Just a quick one, cant find any reference to this sensor on the net.
How do you wire an oil sensor on my yanclone? I'm assuming it switches 12v when the oil drops below a certain level.
Oil level sensor wiring
Re: Oil level sensor wiring
Normally, in cars and bikes anyway, the level or pressure switch connects to ground in low oil situations.....
hmm thats going to make it harder then. I will remove mine from the engine to check how it reacts.
Just as an update, mine was in fact a pressure sensor that connects to ground,
