Trying out the new fuel tap
Well, I finally had enough of diesel leaking from my standard fuel tap and so bought one of the new ones from http://stores.ebay.co.uk/Essco-Royal-En ... let-Spares
So far so good - and it has a reserve unlike the old on push/pull tap.
Apart from the reserve which is usefull & tank removal what is the need for a fuel tap? Are you turning it off when you stop?
bigpaws
runaway diesel = bad news
Post by bigpaws »
fuel tap will allow you to shut down the engine if it decides it wants to run away. there's nothing worse than a broken governor or injection pump which won't allow your engine to stop. it's nice to have an alternative shutoff for the fuel.
Bigpaws
Re: Trying out the new fuel tap
Stu, was this fuel tap for a petrol model? Or, how did you handle the return feed for the diesel?
It was for the petrol model. I've long since sold the Hatz bike but there was a return on it. Never thought it was too well thought out on the Chanwood bikes though - always had trouble with leaks & air getting sucked into the system.
