Differential options for trikes
A room dedicated to those building Diesel Powered Trikes
dieselbikin
Post by dieselbikin »
I've been poking around for cheap, plentiful, and compact, light duty differentials for my diesel trike. So far the best option I've found are Ford pinto and Dana 30 for fully enclosed shaft drive applications. For an open chain drive like I'm using a cub cadet or IH cub works well. As best I can tell they come in one and two piece carriers with two piece being the strongest. Coarse/fine spline axles in 1"/30mm diameters. The strongest setup is fine spline with 30 mm axles. This is what the garden tractor pullers prefer and has stood up to as much as 60hp. A coarse 1" axle should do fine in a 10 hp ya clone application.
1980 Suzuki 550
10 HP Yanclone
94C Comet
