I have a paper copy of the above manual, which came from New Zealand (!), and which I've never found anywhere else. Non-turbo, which is a pain as mine is a turbo...
But pretty much useless except for part numbers and torque settings - mostly a set of exploded diagrams with a few of these things added on. If you're really stuck, message me.
Daihatsu Charade 3cyl 993cc non-turbo
Re: Daihatsu Charade 3cyl 993cc non-turbo
if that is an unbound paper copy or one you can seperate the pages.... then yourself or a friend with an ink jet "office" style printer/fax youl find it likely has ability to "scan to PDF". You can then make it much more accessible via the net.
Thanks for offering.
Also, if anyone is ever needing something digitized, i'll be happy to do it for you.
