MD191 850cc Ruggerini still lives!
Had a correspondance with Lombardini just today & was hearted to learn that the old Ruggerini MD191 I have in the Enfield lives on :D
Andy says...
"I know the Ruggerini MD191 very well as Lombardini bought the company over 10 years ago.
This was cancelled as a model and indeed the brand Ruggerini was itself effectively deleted but the engine lives on as a Lombardini brand – 25LD425-2
From our range my only suggestion (for a bike engine) would be the LDW702FOCS which we can do to 4300rpm max and is used very effectively by the likes of Arctic Cat etc for Quad Bikes, but only has a performance of 17Hp."
An earlier version of that 702 engine is in the German Modite BMW based machine.
royaldragon
Re: MD191 850cc Ruggerini still lives!
Post by royaldragon »
They don't seem to have it on their website. No search option on their site either. I wonder what the price tag is.
dragonmotors.net
royaldragon
Never mind, a little more searching with my glasses on and I found it. :oops: :shock:
dragonmotors.net
Ohhh, could you post the link?
penybryn
Post by penybryn »
Stuart wrote:....From our range my only suggestion (for a bike engine) would be the LDW702FOCS which we can do to 4300rpm max and is used very effectively by the likes of Arctic Cat etc for Quad Bikes, but only has a performance of 17Hp."....
Interesting his suggestion. Stuart would you care to prod him further on this? Why that model as his primary suggestion?
I'm betting it's because they are available with the automotive regulator and it's the biggest twin.
I like the 25LD 330-2, smaller pistons than the 425 so will vibrate less, air cooled for simplicity. Add a turbo/intercooler and your golden.
Hmm I feel a plan coming together.
Reckon you are right there Dave. The Modite bike appears to have no alternator (it would clash with the BMW frame I think). But after asking about this in Hamm the other year I was told it's an option to buy a flywheel with an internal setup.
But to stay on topic, the MD191 had been used by several builders including Reinhard who used it for a small series of bikes. It is well tried, produces about 19hp and has the all important 180 crank for less vibes. Now if it's revs could be increased some.....
It's basically the 2 cylinder version of the Tiger's 1000cc triple.
There are 2 flywheel alternators available either a 3 phase or the 20 amp single phase one that the Tiger has.
henneberg
Post by henneberg »
Hi,
The Ruggerini MD151, the smaller version of MD191, also still lives, but nowadays as the Lombardini 25LD330-2, http://www.lombardinigroup.it/en_US/lom ... 5-ld-330-2
At least the older MD151 was available in different versions, without external filter, and/or oil cooler. I have just shot a MD151 from ebay, that I hope to build into the Enfield frame currently running an Yanmar L100 :D
This one is without external oil filter, no oil cooler and has an electric fuel pump. It should leave more space to reuse the original Taurus inner primary chain case.
The extra good story is, that the original Taurus inner primary chain case just fit to the MD151 flange, it is likely the same used on the Lombardini 325 Taurus in India back in the 90ties. :lol:
skoleskibe
Post by skoleskibe »
Halløj Erik
Jeg har også en MD 151 som skal i et stel (MZ TS250), også som alternativ til en Yanmar L100 :D
Glæder mig til at se hvad du gør!
Kim Svensson
Skibstedvej 23
9293 Kongerslev
mob 31379578
And now in english
Hey Erik
I also have a MD 151 to be mounted in a frame (MZ TS250), also as an alternative to a Yanmar L100 : D
Looking forward to see what you do!
Kim Svensson
Skibstedvej 23
9293 Kongerslev
mob 31379578
Brent
Post by Brent »
