Cav Fuel filter
Cav Fuel filter
Hi all
I have a cav fuel filter, like so:
http://www.ebay.co.uk/itm/Single-Fuel-F ... 500wt_1180
The drain screw on the glass bowl at the bottom is leaking, presumably due to veg oil against the rubber o rings.
Any ideas where I can get a new seal kit or viton seals? I can not find these anywhere! short of buying a whole replacement unit just for the seals!
I also though about replacing it with a car filter unit or one of these:
http://www.ebay.co.uk/itm/Small-Inline- ... 500wt_1180
Can anybody see any issues with either routes?
Many thanks !
Nanko
Re: Cav Fuel filter
Post by Nanko »
A replacement filtercartridge fot the CAV comes with a complete gasket set.
And about the tiny ïnline "filter" I would not use them unless the minimum
particle size the filter captures , is specified.
Re: Cav Fuel filter
Ah okay, many thanks.
Any idea if you can get viton seals, as I think the veg oil is destroying mine :(
Nanko
Re: Cav Fuel filter
Post by Nanko »
I never seen viton quad rings (as used in the CAV), but probably O-rings will work equally well
I can check my stock if you give me the the inner diameter and rubber diameter
Darren
Re: Cav Fuel filter
Post by Darren »
vegetable oil and biodiesel dont really have much effect on most kinds of 'rubber' found in fuel systems. Viton isnt really necessary. The whole issue with vegetable oil/rubber is overblown. Some types of 'rubber' can get a bit weird over time but most are fine. This is far less of a problem with vegetable oil compared to biodiesel.
I sell the CAV/Delphi filters. There are two seals at the bottom. One between the glass and metal, the other under the drain plug. Unfortunately you dont get these rubbers with a new filter cartridge.
If you take the filter apart and clean it all up as long as the rubber parts are not ripped, soft or significantly deformed(swollen) I would expect it to stop leaking when you put it all back together again.
Enfield Bullet with Hatz IB30
www.vegburner.co.uk
