BoxerOtto wrote:hey andrew, another way of getting flat spots on bearings that i have seen in two strokes is people actually over mixing their fuel oil ratio thinking they are protecting the engine when in actual fact the extra oil makes the ball or needle bearing 'skate' or 'slide' and the higher the rpm and thicker the oil the more of a problem it can be. 4000 rpm you wouldn't think would be to fast. What type and weight of oil are you using? One other question is the maximum rpm of the new bearing is almost double as in strait shaft 'electric' motor application, but how about radial thrust load from reciprocating mass? does the manufacturer give specs for other forces. i hope this releativly inexpensive fix works, i'm sure it will. i have only bench run mine for a few hours, but i was told these engines were pre run for up to 1 hr at the factory before shipping. i disassembled mine when i first got it , only to find some very thick greasy oil of unknown origin inside with bits of paper towel like substance on the suction screen.further findings revealed the valve adjustment was loose , the pump and tappet lifters were indeed run for some period of time because they were not rotating and had started to make grooves across the face. bearing journals were fine and a quick lapp of the lifters solved the rotational problems.i suppose the mag ball bearing could go through the same fate as yours further down the road, but i think i will run it as you did and just keep an eye on things. i to am planning a turbo install. keep us posted please!!!
cheers Otto.
Good observation on the bearings in two strokes, I've not seen flat balls but I did manage to flatten every single roller in the conrod bearing of a KX 250, turned the connecting rod a nice shade of blue too
. Could have killed the guy controlling the gates at the time, but hey that was/is racing = and another story.
Run your engine like you said, take not of what it sounds like - as stated this bearing could have gone for a short time or for ages as no hard facing was lifting.
I couldn't find any info on radial thrust, but C3 bearings are the preferred ones in engine cranks if you need to use this type of bearing.
The oil I use is Valvaline XLD 20W - 50 which is turbo diesel approved. Many of you guy's in the UK/US etc will think its toooooo thick, I agree for your climate, here in Australia it gets bloody hot and this oil has been brilliant, I use it in all vehicles for years without problems. I also noticed the oil sticks to everything in the engine, was even evident in the bore, sticking to it like s**t sticks to a blanket
Oil changes are/were done at 1hr, 100 klm, 1000 klm and thereafter at intervals of 2000 klm. The oil isn't cheap, but neither is getting a bike transported back to home and is good security.
Anyone who has just purchased one of these engines. before you put the engine into a bike, run it for an hour with fresh oil and then drain the oil, pull the oil filter out and clean it, you'll be amazed at how much crude you might find.
Looks like you thoroughly went over your engine boxerotto, great stuff. You shouldn't have any troubles, just keep bearing noise in mind. The other thing is to turn the fuelling down till only a small amount of smoke is emitted, these engines are over-fuelled at factory setting.
A
