Winsun 192 anyone
Winsun 192 anyone
Who else has experience with these engines?
Re: Winsun 192 anyone
I’ve no actually experience with them but as with the Punsen, they are Chinese knock offs I believe & it’s best to build a bike around an original Yanmar if one is available.
I’ve seen fuel lines crack due to not being supported on the copy engines & other things that compromises their longevity.
Sorry I can’t be more specific & can only give an overview.
Thanks for reply.. i will try the failing 192 engine once more.
But i cannot find any info about the fuel delivery angle and at what torque the - removed and now checked- injector has to be fastened?
I cannot belive 7nM is enough?
There was RUST in the injector of the new engine, i discovered it recently...
Ooo that’s not good!
No, since an injector is closed at rest, i wonder how..
Anyway, the 10-12Nm fastening torque for the injector seems low? Because of the high compression of the engine?
Or is this (again) marely in my head?
Does anyone have an exploded view of the engine?
The section where the fuel pump is, is different for the 188
There's a lid between the pump houding and the engine, and forgot if there's a copper gasket on booth sides (which influences the timing)
I cannot find one online?
I found out another flaw; Why the flywheel spinned over the crankshafft despite tightening the big nut; The taper does not align with each other..
There's no source for spare parts for these engines?
Engine is running again! With the help of valve-lapping paste, patience, loctite 648 and a electric spanner (What's it called in English?)
I de-aired the fuel line but, rpm, especially when half throttle, is fluctuating very much, idling is not possible..
Fuel flow is allright
Does anyone have a tip?
I figure the smaller of the 2 governer springs have something to to with de stabile run at lower load/rpm's. I hailed 3 Yanmar-dealers for a set of springs (both springs have 2 numers at the drawing, that means there are 2 types of each?) but not one of them responded.
