Official "kuzuki" build
Paradox1559
Post by Paradox1559 »
Well, the time has come. I have everything I need to build my bike.
I will be using a 1972 suzuki gt750 "waterbuffulo" or "tea pot" ($250.00). It came with another bike so I'm not worried about harming a classic.
My motor is a kubota zb600c-1 ($20.00), out of a wood chipper I think. I picked it up out of a scrap yard of all places. It has 400psi, but it looks like the p.o. ran it out of fuel and gave up trying to bleed it.
For now, I will be using a cvt clutch pulley setup($60.00)
Paradox1559
Re: Official "kuzuki" build
Paradox1559
Well, here goes nothing.....
(Suzuki lovers avert your eyes)
garbs
Post by garbs »
Very interested to watch the build. I have always been interested in those engines and thought they would be perfect for a bike with the cylinders horizontal making for a short engine as opposed to most engines others including myself use, which tend to be very tall.
Paradox1559
Well, I still have some math to figure out, but the frame is now bare. But as it looks, I won't even have to remove the radiator. It's almost as if the two were ment for each other.
Paradox1559
Turns out I can't use the integrated radiator. So, I removed it and found a nice plate of aluminum.
I aim to add a thermostat, on the outlet, and just a simple coolant barb for the inlet. I can even use a 12v. Coolant pump from a prius.
Without coolant manifold
New manifold plate
Before you get to far into it...... check with a Kubota guru like North Idaho Wolfman.... (you know whom he is). Think there is possibility you can swap front case and water pump from a later bota that uses same block but whose front case has a water pump etc... Like a d602... ??? who knows maybe the D722
Paradox1559
I don't be able to afford that. I'm building this on a tight budget.
Paradox1559
I finally got the motor resting in the frame. It seems to fit well, but slightly tight.
The cvt should work.....I've not seen it done this way, so we should see how this pulley works on top of the "drive" clutch.
Paradox1559
it's been a minute, but im making progress. I just picked up a new job so my funding is back and im gonna be buying the last bits I need to finish my bike. I can't lie, Im SO excited Im wetting myself. I should have some pictures soon, so i'll have those up in no time.
Paradox1559 wrote:it's been a minute, but im making progress. I just picked up a new job ...
congrats on new job and your wet pants lol.
we should have an OH get together at some point.
coachgeo wrote:we should have an OH get together at some point.
If you guys could tolerate a Hoosier, I'd love to join you. Maybe bring a few bikes along while I'm at it.
Paradox1559
I would be totally game. I'm gonna see about getting something together if I can't find anything. This little project has a bunch of people around me looking for motors of their own.
Paradox1559
https://youtu.be/56RtdQZIgBI
I've made some real progress this month. I found a good set of air tanks that I'll use for fuel. I have the "clutch" set up (pictured is not what I'm using.) it's got all non essential equipment wired. Also My cooling system is only missing a pump. I also need to fabricate a whole new stainless steel exhaust
I drove it yesterday and i need to tweek the ratio. It only goes 45mph/72kph, and that just isn't enough, It's basically a giant minibike.
Although I only had a mile of road to work with and it felt like it had more to give.
