MD190 upping 2400 revs to 3600rpm+
Post by Anorak_ian »
Hi guys, :)
I'm thinking of using a Ruggerini MD190 on one of my bikes, but the revs are set at 2400rpm. :?
Being as it is a MD190 it should rev to 3000, and I'm betting it will if the throttle stops are opened up.
Here's the question: How do I get it to 3600rpm (MD191)? Is this just throttle stop adjustment alone, or will it be governor as well?
Cheers guys.
Ian
henneberg
Re: MD190 upping 2400 revs to 3600rpm+
Post by henneberg »
Have a look page 39 ff in the workshop manual: http://www.dieselbike.net/manuals/Rugge ... MD_191.pdf
I hope it will explain about speed and governor setting :)
thanks, I have a manual, I was hoping to find someone that has done it and has knowledge of these engines.
My RD210 engine (3000rpm)is now a RD211 (3600rpm) with the throttle stops bent over with the help of a hammer (3700rpm) :lol: I was hoping to hear this MD190 engine was up revved the same way.
XLerate
Post by XLerate »
Just an aside comment here: in some cases like the Bosch VE pump if you change the top governed speed by changing the governor spring it can also change the entire fuel curve. That is, while you can sometimes gain top end power along with higher rpm's you can also lose some bottom end fueling and power. Worth researching before investing time and money in a different spring.
Thanks for the info.
I think I have the answer I was looking for, looks like the whole 3600rpm (3750rpm) is down to the throttle stop screw, as its way longer than others that I have seen.
Also the throttle lever has very little swing to it, so I'm guessing it has a higher throttle gearing compared to my RD211 engine.
Sorted :D
jonnyr48
Post by jonnyr48 »
hey ian,how much did you screw it in in the end?im using the same engine, and was wondering how to get the right revs without anything complicated.
cheers, jonny.
Hi Johnny, I didn't get the MD190 in the end. I was out bid.
I do like to get all the info that I can before parting with my cash.
But on my RD211, I took the throttle stop screw out completely. :D
jonnyr48
Post by jonnyr48 »
thanks ian....completely? hmmmmmm, not too sure i´ll go quite that far.... :)
cheers, jonny
